88 K5 Steering Loose
I recently bought an 88 k5 and drove it home with the steering wheel very sloppy to the point that I was all over the road. I had to learn to play with the steering to compensate for the very sloppy steering. Picked it up for 3800 and for all the work done to it I just took it as is. Many upgrades to engine and tranny. Now I need to fix the steering. Any help would be appreciated.
*Moved to a thread of your own in the Fullsize Tech Section* Please read the section descriptions and choose appropriately as well as try not to post your questions in someone else's active thread unless it exactly matches and adds to that discussion.
To add to what Tom A has already suggested, I would also suggest that you get under the front end and look/feel for play in the steering tie-rod ends while someone else moves the steering wheel back and forth. The stock setup has 4 tie-rod ends andplay from even slightly worn joints results in very exaggerated and sometimes erratic steering movements. I replace the joints in the "dog-bone" (the link from the steering gearbox pitman arm back to the arm on the driver side steering knuckle) on my '74 when I started having trouble with the all too common 'death-wobble' at speeds over 45mph and that helped dramatically.
