89 Blazer 5.7 Stalled won't restart
Old Mar 24, 2011 | 02:25 PM
2dogs2's Avatar
2dogs2 is an unknown quantity at this point
Default 89 Blazer 5.7 Stalled won't restart
My 89 5.7 stalls about 10 minutes after starting and will not restart for an hour or so.
I've replaced the ICM, plugs, cap, rotor, wires, and coil. I have spark and fuel, but for some reason it won't restart once it stalls for an hour.
Don't know where else to look ??
Old Mar 24, 2011 | 08:43 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
for fuel did you check pressure? should have 62-90 kPa (9-13 psi) engine off key on
Old Mar 26, 2011 | 02:14 PM
helo's Avatar
helo is on a distinguished road
If it doesn't start, then you probably don't have spark & fuel! Good spark & 9-13psi fuel pressure. If it will fire up with gas poured directly in the TBI then it's probably low fuel pressure (time for filter/pump)
Make sure ICM has good ground (dizzy bolt tight). Your timing might be set wrong. Rotate engine to TDC with breaker bar on crankshaft pulley bolt and see where the distributor is pointed. Verify it's TDC and not exhaust stroke by pulling spark plug #1 and feeling for puff of air as the timing notch on the harmonic balancer starts to approach the timing tab.
From there you can try advancing it a bit to get it started, and then reset it with a timing light (turn dizzy counter-clockwise to advance). It'll idle anywhere from 10* retarded to about 40* advanced when the EST wire is unplugged, smoothest idle will be around 20*-25* advanced (ICM controls this based on the ECU PROM when the EST bypass wire is connected)
You can also hook an LED+resistor to the tach wire off the coil and see if you're getting proper spark pulses from ICM when you crank.
Old Mar 26, 2011 | 03:36 PM
2dogs2's Avatar
I have spark and fuel, (pressure 11psi) if anything by the smell I have to much fuel. Could my TBI be dumping to much fuel and flooding the plugs?
Old Mar 27, 2011 | 10:27 AM
2dogs2's Avatar
I just replaced the coolant Temp Sensor and SHAZAM My problem is fixed !
Figured for $12 it was worth the test since I thought for some reason it was flooding.
Thanks..
Old Mar 27, 2011 | 07:13 PM
Z71_Guy's Avatar
ya those coolant temp sensors can cause some crazy thing.
Quicksilver
Jan 13, 2011 11:40 AM
ekerry
Oct 3, 2010 01:27 PM
Son of Odin
May 4, 2009 08:39 PM
debb41
Nov 14, 2006 08:06 PM
debb41
Nov 14, 2006 04:21 AM
