89 blazer will start then stall
Old Nov 22, 2007 | 02:24 PM
dcn427's Avatar
dcn427 is an unknown quantity at this point
Default 89 blazer will start then stall
It will start then stall. start, run a few seconds then stall. It started about a 2 weeks ago and it only gets worse from there. It use to take 5 minutes to get it to stay running.then it was 10 minutes then 20 minustes and this morning it was 30 minutes to get it to start and stay running. i have no idea what to do. .
I have read through the other post and have cheked the fuel pump which is fine. next i haver changed out the rotor cap and button. with spark plugs and wires. the Fuel relay is good and the throttle body is still good. any ideas thanks.
Old Nov 23, 2007 | 12:21 AM
Chevy Lover's Avatar
Default RE: 89 blazer will start then stall
When you have a question it's always helpful to enter your vehicle info either in your post or with your signature.
I'm thinking that you may have a problem with the ignition module. I don't know what they're worth in the USA, but you're local Autozone may have a tester.
Old Nov 23, 2007 | 10:18 AM
dcn427's Avatar
sorry about that. Its an 89 Blazer with 350 motor 4wd auto. and ty I will get the module tested. I got the last one at autozone. So ill take it back.
Old Feb 11, 2008 | 08:02 PM
dcn427's Avatar
Hey chevylover thanks for your help. It turms out it was the fuell pump after all. the exhaust was blowin right on top of it. the heat was too much for it to handle.
barnesto
31
Jun 11, 2014 07:12 PM
Finding DeMo
Jan 15, 2014 06:23 PM
kuojo
Mar 28, 2012 07:22 PM
longhorn4x4
Apr 25, 2011 07:03 PM
