new starter (info needed)
Old Aug 1, 2010 | 01:29 PM
codybarber1315's Avatar
codybarber1315 is on a distinguished road
Exclamation new starter (info needed)
Just purchased a new starter for my 84 k5 when i removed the old starter there were no shims in place and eveyrhting seemed to work fine. But with the new starter it seems to have a slight grind noise for maybe a hlaf a second before motor fires is this ok or is there a adjustment that needs to be made if so what?
thanks in advance for any and all help.
Old Aug 1, 2010 | 02:06 PM
If it grinds, you should adjust it so that it doesn't grind. You can get starter shim packs that have various different thickness shims in them. Most starters come with directions and a little go/no-go gauge for checking proper adjustment. The go/no-go gauge looks like a rectangular keyway.
Old Aug 6, 2010 | 07:32 PM
garciamode's Avatar
garciamode is on a distinguished road
I think that if it whines before it starts the starter gears are too far away from the flywheel so you would want to add a shim on the outside starter bolt side to bring the gears closer together. Thats what I did on mine and it works fine now.
hzl6cm
Jan 15, 2013 08:36 AM
abc
Mar 17, 2007 07:52 PM
AleroGuy
Engine & Internal
Nov 14, 2006 02:47 AM
hillbillyinOhio
Aug 12, 2006 01:48 AM
neogeo92
Sep 27, 2005 02:12 AM
