91 rear-end help
Old Oct 8, 2010 | 10:26 PM
84beau's Avatar
84beau is on a distinguished road
Default 91 rear-end help
I am looking to beef up my rear-end. My carrier is cracked in half and not sure what else is broke. Looked at the 14bolt 1ton conversion axle with 6 lugs. Waste of money? Otherwise, I will re-build it. Any suggestions on decent, not so expensive parts? Where to get a cheap assembly?
Any help is greatly appreciated...
91 k5, 342 gear ratio.
Old Oct 9, 2010 | 07:56 PM
The 1-ton axles are not 6 lug. Your best bet would be to find a 3/4 ton truck and take the front and rear axle from it, converting to the 8-lug axles.
Old Oct 10, 2010 | 09:14 AM
84beau's Avatar
Here is the link for the 14 bolt conversion
http://www.drivetrain.com/parts_cata...onversion.html
Old Oct 10, 2010 | 09:45 AM
I guess I should have clarified my statement to include the word 'stock'. That article is far from stock.
Just my opinion, but if you are going to go through all of the trouble and expense of upgrading the rear axle to a 14 bolt, you really should go with the full floater, not the semi-floater that is in that article. Also, your front axle will be the next weak link. Besides, that custom axle is going to likely be more expensive than doing it right.
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
moe_23
Dec 19, 2007 04:23 PM
2klt
Apr 28, 2006 09:36 AM
