92 Fullsize with brake problems
Old Jul 2, 2009 | 07:16 AM
House2272's Avatar
House2272 is on a distinguished road
Default 92 Fullsize with brake problems
I have a 92 fullsize blazer 4wd with a 5.7 engine. I'm having nothing but problems with the brakes! I have recently replaced the front pads and rear shoes. In addition to that, I have bleed the brakes about 10 different times. I still have a very spongy pedal? The idiot ABS and Brake lights are constantly on and everytime I try to read the codes, it gives me every code that is listed for ABS brake problems. Please help! Thanks.
Old Jul 2, 2009 | 08:42 AM
billymac49's Avatar
billymac49 is on a distinguished road
any fluid leaking? check all connections and lines for leaks. check master in the engine compartment and under the dash for any wetness. also deteriorated rubber lines can give you a spongy pedal (this you won't see it happens from the inside). if the rubber lines look cracked or dry rotted you may want to replace them anyways.
Old Jul 2, 2009 | 10:05 AM
gearyr's Avatar
gearyr is on a distinguished road
ou may have to replace the ABS unit under the hood. My sons 92 did the same thing as yours. Got a used one at a salvage yard. Put it on, then the ABS light went out. Then about 2 weeks later. The brake light came on and hardly no brakes at all. Checked the master cylinder and it was almost empty. Had to replace the front pads. They were about gone. Then we checked the back brakes. Had a wheel cylinder leaking really bad. Replaced both of them. Bleed the brakes, brake light is off. And the brakes are great. gearyr
Old Jul 3, 2009 | 12:01 PM
House2272's Avatar
billymac49,
No fluid was leaking anywhere. I forgot to mention that all the brake lines to the calipers and the rear were replaced with stainless steel braided lines.
Old Jul 3, 2009 | 01:50 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
sounds like there is still air in the system..Try bleeding your brakes starting at the right rear,then left and do the same up front..Right side then left...Make sure you keep the master cylinder full or you will suck in air and have to do it over..
edonwheels
Jul 9, 2013 10:01 AM
932d
Lowering Tech
Jan 20, 2010 10:14 PM
bigblueblaze94
Dec 7, 2009 07:04 AM
Bige4457
Nov 2, 2007 01:45 AM
Bige4457
Jun 8, 2006 10:11 PM
