92 TBI 350 cough/stumble at low throttle
Old Aug 5, 2010 | 08:06 AM
Hizapitt's Avatar
Hizapitt is on a distinguished road
Default 92 TBI 350 cough/stumble at low throttle
I have a 1992 Blazer with a 350 TBI, automatic. At idle is sounds fine, going down the road on the gas seems fine. If I take off very easy it stumbles of coughs. The entire truck chugs. Some times if I let of at low speed it almost acts like it will die. Things to note, seems to idle high all the time, let off the gas and it will go 15 to 20mph with no throttle, gas millage is between 11 and 12 mpg. I just bought the truck and figured it needed a tune up so, new plugs, wires, cap,rotor, MSD coil, fuel filter and today thinking it was a fuel pressure issue I replaced and the pressure regulator. I can not find a vacuum leak any where. Oh, new 02 sensor as well.
Ideas????
Old Aug 5, 2010 | 05:35 PM
I would check the throttle body base gasket (between the throttle body and the intake manifold). I have seen these fail and cause very similar concerns.
Old Aug 9, 2010 | 02:10 AM
nortonii's Avatar
nortonii is on a distinguished road
i have the same prob. but with low to normel idle. mine is a 87 350 tbi if you fig it out let me know i will do same.
tech180
Feb 2, 2013 10:23 AM
Repus J 13
16
Apr 6, 2012 09:37 PM
deathman
Aug 14, 2011 11:25 PM
boxken
Apr 24, 2011 12:33 AM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
