Black smoke and won't idle?
Old 01-18-2013, 04:23 PM
Bake's Avatar
Bake is on a distinguished road
Originally Posted by THePaRaSiTE5771
Since you described seeing black smoke, as previously mentioned, that is fuel. I'm just throwing it out there, but if I were you I would replace the coolant temperature sensor on the top of the intake next to the upper radiator hose. These go bad often, and when they do, the injectors dump way too much fuel down the TB and it will never run right. Even if this isn't the problem, it is still good to replace this sensor because the they go bad VERY often. They should be a common maintenance item.
Thanks, I'll definitely try it and see if it helps.
Old 01-19-2013, 11:28 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Usualy a temp sensor if its goes bad it will throw a code but its a cheap part so it cant hurt .
Old 01-19-2013, 01:30 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
On these TBI motors, when the temp sensor goes bad it rarely ever throws a code. I've replaced them countless times and maybe 5 vehicles threw a code when it went bad.
Old 01-20-2013, 11:36 AM
Well depends on the vehicle I guess my truck is a 94 with tbi 4.3.Mine went bad and I got a codes.Multiple codes I changed the coolant sensor and fixed.Ironicly Im having the problem a code for multiple problems.I changed the IAC sensor that fixed it for a while noe the light will come back on at a long idle period.
wolfmagicsong
05-16-2013 09:26 AM
adanac
05-22-2008 07:21 PM
megtom2
18
02-21-2008 03:40 PM
CrashPro993
11-08-2007 04:32 PM
disturbedgame
05-02-2007 09:18 PM
Quick Reply: Black smoke and won't idle?
