brake booster/master cyl.
Old Aug 3, 2012 | 05:49 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default brake booster/master cyl.
hey yall im gonna replace my brake booster and master cylinder this weekend never done it befor could yall lemme know how its done ..without trippin that combonation valve oh its in a 78 k5 fulltime 4x4 350
Old Aug 3, 2012 | 08:11 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Create an account on autozone.com and use their repair manuals.
Old Aug 4, 2012 | 12:25 AM
well im gettin the master cylinder and booster already put together ..i was thinkin i should take the master cylinder off the booster because it would be easier to bench bleed it off the booster then hook it back up and install it does that sound about right?
Old Aug 4, 2012 | 08:06 AM
abig84's Avatar
Yea I would do it off the booster. The booster is pretty self explanitory. There's 4 bolts holding it on. There MAY be 2 under the dash, I don't remember if that was hydroboost or vacuum that had those two. Anyways if it doesn't come off when you take the 4 off that's why. Then just unhook the rod at the brake pedal and that's it
Old Aug 4, 2012 | 01:03 PM
so for the master cyl. ill just put it in a vice to hold it put those little plastic caps they give you on the ports fill it up and pump that little lever till brake fluid seeps from the plastic caps is that about right?
Old Aug 4, 2012 | 07:36 PM
abig84's Avatar
the way ive always done it is instead of caps they sometimes give you plastic fittings with a hose, i thread those into the master cylinder then put the hoses into the top of the master cylinder into the fluid, that way when you push and let off youre not sucking air back in.
im not saying you cant do it with the caps, i just dont know how if there is a way
Old Aug 4, 2012 | 09:43 PM
hey thanks yall i got it just fine breaks are workin like they should ..i shoulda got off my *** and done it a long time ago now i can drive it up to the mountains to my uncle shop to lift it next week.
UPRocker
Oct 22, 2014 10:03 PM
iamchevyman5
14
Aug 13, 2012 11:20 AM
Logan
Nov 12, 2010 09:16 PM
Tallahasseeblazer
Oct 15, 2009 09:02 PM
s10machine
Mar 24, 2008 08:17 PM
