Brakes sticking
Old Jul 31, 2017 | 06:33 PM
Stokes0802's Avatar
Stokes0802 is on a distinguished road
Default Brakes sticking
I have both front brakes not releasing, both calipers and soft hoses have been replaced and the problem still persists can someone please point me in the direction to solve this issue
Old Nov 12, 2022 | 04:40 AM
Rodney gullion's Avatar
Rodney gullion is on a distinguished road
Default Chevy Blazer
do you have a good firm pedal if the plunger is not working correctly in the master cylinder it will not pull back the fluid for the piston in the caliper to release remove your caliper and try working the Piston back and forth a few times and gently press the break and see if they are working properly then reinstall I had a new one not released and my boss drove it home and chewed up the new brake pads and the rotor because the Piston would not release in the caliper for some unknown reason but the other three old ones did so I wound up changing out the master cylinder and cleaning out the lines and that seemed to fix it
di$TOrTed
Oct 17, 2012 10:38 AM
pbd3mon
Oct 23, 2011 01:45 PM
filthysanches
Aug 18, 2010 12:22 PM
toaks1
16
Jan 20, 2010 08:12 AM
pigmak
Aug 23, 2009 09:26 PM
