dash lights/running lights problem
Old Nov 8, 2011 | 07:34 PM
Steeltoe623's Avatar
Steeltoe623 is on a distinguished road
Default dash lights/running lights problem
Hey everyone, its been a while. Last month I bought a 1991 4x4 K5 Blazer with a 350 tbi engine. I've been going through fuses like crazy. One night I went to flip the headlights on and the dash lights went out, and also noticed that the running tail light lights were out as well. Headlights worked fine though. We've already checked the fuse box and made sure all appropriate fuses were where they should be. We checked to see if there were any loose wires around the trailer hitch. We replaced the wiring and bulbs on both passenger and driver's sides for the brake lights, reverse lights and turn signals. Other than that, I'm stumped on what else it could be. Any help or advice would be greatly appreciated.
Old Nov 11, 2011 | 05:41 PM
Fahad's Avatar
Fahad is on a distinguished road
based on what you said I think you need to open the dash board and check the circuit behind maybe there is some dust got inside and cutoff the circuit of the dash light.
For the rear light I guess there must be a loss connection that lead to this issue.
Old Nov 12, 2011 | 03:10 PM
abig84's Avatar
the dash lights and running lights run on the same fuse (as you obviously found out) pull your tail lights out also. make sure none of those wires are stripped and grounding out. seen it happen before. if nothing behind dash or behind tail lights looks bad trace the wiring harness along the frame for cut or crusty wires.
AlwaysSomthin
Sep 3, 2011 03:30 PM
antman94
Mar 7, 2011 08:12 PM
Benedict1337
Dec 10, 2010 08:30 AM
ff162bfd
Oct 26, 2009 11:23 AM
Aneurysm
13
May 3, 2008 12:27 AM
