Door locks
Old May 19, 2011 | 07:37 AM
DANGLE1976's Avatar
DANGLE1976 is on a distinguished road
Default Door locks
My 94 full size blazer's door locks are frozen from the outside. I can use the power locks on the inside but can't lock the doors because i can't get in! What should i do besides replace the locks? Pb blaster,wd 40,etc doesn't help!...thanks!
Old May 23, 2011 | 05:31 AM
Magmotor's Avatar
Magmotor is on a distinguished road
Both the driver & passenger locks will not lock or unlock using the key??? If that's the case, sounds like some kid used some super glue down both locks.....or you have the wrong key, does it still open the rear window & door? I'd go for removal of the passenger door lock and find out why the key won't turn....just my 2 liras.....
Old May 23, 2011 | 07:56 PM
DANGLE1976's Avatar
Yes both locks stiff as a board!!!..will try the back window....if not will just replace the locks!!!..just being cheap!
ussexplorer
May 11, 2011 09:04 PM
truck608
Oct 14, 2007 11:56 PM
Craig Austin
Nov 14, 2006 01:20 PM
Craig Austin
Oct 22, 2006 06:48 PM
Bojib
Jan 27, 2006 01:29 AM
