Engine heats up, then cools off, heats up again
Old Apr 29, 2005 | 10:29 AM
JVS's Avatar
JVS
JVS is an unknown quantity at this point
Default Engine heats up, then cools off, heats up again
I have an 88 blazer, 5.7l. When I start it up, the engine begins to warm very quickly, and the guage buries into the red, and then the temp drops within range, then heats up again, etc...Sounds to me like a bad thermostat, but I just changed it a few years back. Does it definitely sound like a bad thermo, or maybe a faulty guage or sensor? Or, is there something else worng?
Thanks,
Old Apr 29, 2005 | 03:40 PM
Patrick's Avatar
Patrick has disabled reputation
Default RE: Engine heats up, then cools off, heats up again
it sounds like you have a bad thermostat to me...thats what i woudl check first...its nice out, so take the t stat out altogether, and see if that fixes the issue.
Old Apr 30, 2005 | 08:31 PM
dobbist's Avatar
dobbist is an unknown quantity at this point
my truck althogh not to that extreme is doing pretty much the same thing and i replaced the thermostat still no change but thats me. are you losing any coolant?
Old May 1, 2005 | 01:55 AM
dobbist's Avatar
ok i think i might have found a leak finnaly on my truck i noticed today. after i drove it home from work today, i refilled the radiator let the truck cool off filled it again walked away for 30 minutes then filled it again all and all about half of a fresh jug. it seems to not want to be full always about 2 or 3 inches from the top of the radiator. after refilling it the third time i drove it for about 20 minutes and checked the engine, and on the passenger side i noticed a slight pool of coolant on top of the engine where the vlave cover and intake manifold meet. i checked the heater hose as best i could but could not see any moisture on it or where it goes in the engine. does this at all sound familiar to anyone?
Old May 1, 2005 | 09:36 PM
JVS's Avatar
JVS
I took the thermostat out and it runs cool and does not fluctuate. Obviously the thermostat I just put in a year and a half ago is a peice of crap. Had a lifetime guarantee??!! Like Chris Farley said, "I can S#!T in a box and stamp it guaranteed". That's about what I got. Anyway, I guess that's a lesson learned. Would it be OK to leave the thermostat out?
Thanks,
Old May 2, 2005 | 11:17 PM
dobbist's Avatar
i wouldn't recomend it after all the thermostat is bascily in part a safety feature to keep your engine from over heating among other things
Old May 2, 2005 | 11:20 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
if it runs too cool, it will never get up to operating temperature and the oil won't flow as smoothly as it should. it could also gum up in cold weather causing a lot of problems. id put in a good thermostat.
Old Jun 12, 2005 | 11:00 PM
outthedoor's Avatar
outthedoor is an unknown quantity at this point
get a fail safe thermostat that way when it does fail it will be in the open position.
Jack88cannon
Aug 22, 2015 05:39 AM
ceo84139
May 22, 2014 01:39 PM
gatelocked
Feb 28, 2011 04:52 PM
KRUSHER
Jan 2, 2010 07:25 PM
scn1010
Engine & Internal
Jan 19, 2006 12:57 PM
