Engine runs cold
Old May 18, 2011 | 11:37 AM
1992 blazer's Avatar
1992 blazer is on a distinguished road
Default Engine runs cold
Hi everyone . I have a few problems with a 92 blazer i just bought . I'm trying to get it registered but it won't pass smog . Has very slightly high hydrocarbons . I did a full tune up and checked for vacuum leaks and still no change . I can't get the engine temp above 150 degrees . Changed the thermostat 3 times , blead the cooling system and replaced the temp. sending unit . I don't know what else to do without just throwing money I don't have at it . Any help or suggestions would be greatly appreciated . By the way it's a tbi 350 .
Old May 18, 2011 | 11:49 AM
Have you replaced the coolant temp sensor? Its possible that the temp sensor is passing the wrong engine temp to the ECU which is causing it to stay in fuel enrichment mode resulting in your high HC count.
Old May 18, 2011 | 01:39 PM
Yes . I replaced it with no change in the temp reading . Even after driving it for 30-45 mins you can grab the upper radiator hose . Am i correct in assumong that when the engine stays below proper operating temp it will run rich and therefore fail smog on hydrocarbons ?
Old May 18, 2011 | 01:41 PM
That is correct. Something in the system is bypassing the thermostat, allowing the engine to run too cool.
Old May 18, 2011 | 02:27 PM
Banging my head against a walltrying to figure this out . Seems like it should be a fairly easy fix . Lots of people have experience with hot running engines but very few seem to have had this issue .
Old May 19, 2011 | 06:37 PM
87/89 blazer's Avatar
87/89 blazer is on a distinguished road
have you tried the rad. cap . if not holding proper presure may make run cold.
Old May 19, 2011 | 06:57 PM
It has a 16 lb. cap on it right now . I tried running it for about 20 minutes with no cap on and it still never got very warm .
Old May 22, 2011 | 01:17 AM
sagefisher's Avatar
sagefisher is on a distinguished road
Does the rad look recently replaced? if so could be a larger one with more surface area or more cores causing the cold running. Up here in Canada you will often see cardboard placed in from of grill/rad to reduce cooling area allowing warmer operation in the winter...may help for a temp fix.
Old May 22, 2011 | 10:24 AM
The radiator doesn't look new . I am going to try the cardboard thing today . Off to buy another t-stat as well just because 3 in a row just doesn't seem to be enough .
Old May 23, 2011 | 11:00 AM
sagefisher's Avatar
Before you buy another t-stat have you tested any of them?
throw one in a pot on the stove turn it on high and use a cooking thermometer to see what temp it starts to open at. It should start pretty close to the rating so if its a 190 I believe 180ish would be close to when it begins.
