frame mount fuel pump set-up, on a K-5 with a V-8 carb. motor
Old May 9, 2012 | 09:08 PM
belljl's Avatar
belljl is on a distinguished road
Default frame mount fuel pump set-up, on a K-5 with a V-8 carb. motor
I've never mounted a fuel pump in front of the gas tank on the frame rail before. There's no room by the frame rails in the engine bay to mount a mechanical fuel pump on the block. This is not the original engine. It's a V8, could be a 305, not to concerned about that yet. It is a K-5 Full-size blazer 1983.
Anyway, I've seen some Holley electric fuel pumps with a fuel regulator built in the same unit, for carb. type engines for about $130.00. I could use a little instruction on this one please. I've been looking for some kind of demonstration video on fuel pumps, or whatever I can find. Thank You, have a good day.
Old May 10, 2012 | 06:54 AM
rriddle3's Avatar
*Moved to 'Full Size K5 Tech'*
Old May 10, 2012 | 08:21 PM
abig84's Avatar
they are pretty simple as it gets. had one on a old s10, you just cut the fuel line somewhere, theres usually a rubber section under there. the pump will have two nipples on it, just plug them into the rubber lines and its installed. they do sell electric fuel pumps for carb engines, where they only put out like 5psi, again had one for my carbed s10 blazer.
you just ground the ground, then run the postive to a fuse that goes on when the truck has the key in the on position
Old Jun 1, 2012 | 10:38 AM
70-K5's Avatar
70-K5 is on a distinguished road
20 days later.. but how do you not have room to mount the mechanical fuel pump?
there. You shouldn't have any issues with the amount of room under the hood.
On another note, did you get it fixed?
Brandon Smith
Dec 22, 2013 12:33 PM
slowsinglecam
Performance & Brainstorming
Jun 18, 2012 11:49 PM
MrDave14
May 4, 2011 09:40 PM
Razorburn71
Apr 21, 2011 06:39 PM
wyk
Dec 18, 2008 05:47 PM
