front drive shaft length 86 K5
Old May 23, 2013 | 09:18 AM
TexasRider's Avatar
TexasRider is on a distinguished road
Default front drive shaft length 86 K5
Anyone know if the front driveshaft is long enough in stock form for a 6-8in lift?? I took mine out yesterday because there was alot of play where the rear part of the shaft slides into the front part. I mean it wiggled about 1/2 to 3/4in easy. Im not sure if that threaded collar is worn out or if the shaft is just too short stock.
Old May 23, 2013 | 11:34 PM
abig84's Avatar
yes and no.... it seems to differ for whatever reason. i have put a 6 inch lift on 3 different k5's and 2 of them they were fine and on the third one the splines started to pull out
if that spline section moves up and down then yeah its worn out. ive had a driveshaft as bad as youre describing and figured i would wait til it broke and it never did
Attached Thumbnails front drive shaft length  86 K5-suburbanfrontshaft_zpsbfa3cb5a.jpg
Old May 24, 2013 | 06:13 AM
TexasRider's Avatar
I didnt want it to break as I run down the highway...risk tearing up the trans and t-case...lol Ive heard a few ppl say they make a spacer that bolts to the shaft and t-case..I wonder if thats a good option instead of having a longer shaft built.
Old May 24, 2013 | 11:48 AM
70-K5's Avatar
70-K5 is on a distinguished road
If your hubs are unlocked and the transmission is in 2-Hi then your front shaft will not be spinning.
In my experience 4" is ok for stock shafts, if you go to 6" and higher you should buy new shaft or have your existing shaft re-tubed.
Old May 24, 2013 | 05:47 PM
TexasRider's Avatar
Thanks...im looking into having mine lengthened. Ive heard mixed emotions about using a spacer
Old May 28, 2013 | 11:23 AM
70-K5's Avatar
You'll probably need more than a 1" spacer can give you.
Old May 29, 2013 | 06:50 AM
TexasRider's Avatar
Yea, I found a place here that will lengthen mine. Im still hunting for a slip yolk tho ha
Xavier
Apr 11, 2014 11:49 AM
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
yarinzim
May 10, 2010 09:20 AM
wormburnr
Nov 4, 2006 03:42 PM
