Rear End Shaft Length
Old May 9, 2010 | 08:05 AM
yarinzim's Avatar
yarinzim is on a distinguished road
Default Rear End Shaft Length
Hello!
before i can order the right shafts for my truck i need to be sure that i order the right one.
because i live outside the U.S and it's a bit impossible for me to return in if I'll get the order wrong.
so the truck is Chevrolet blazer k5 90, with gm 8.5" 10 bolt rear axle with 6 lugs and 28 splines on the shafts.
the man I'm ordering the shafts from needs to know the length of the shaft.
if anyone knows the dimensions of the shafts, it will be very helpful.
Thanks in advance, yarin.
Old May 9, 2010 | 11:48 AM
abig84's Avatar
Post what trans and transfercase you have too and how high of a lift if any. Those all come into play
Old May 9, 2010 | 01:58 PM
yarinzim's Avatar
are you sure all this info is required?
i mean, the rear axle I've got is probably the original one, so there's must be only one type of shafts in it, am i right?
one way or another, I'll post the requested info.
Yarin.
Old May 9, 2010 | 06:43 PM
I think abig84 was thinking you were looking for the rear drive shaft. Not the axle shafts themselves.
My references show that you should have a 30 spline 10-bolt with the axle shaft length of 31-5/16". It is the same length on both sides for the rear axle.
Old May 9, 2010 | 10:04 PM
yarinzim's Avatar
OK, i already know i got the 28 splines, there's a brand new detroit locker I've installed by myself so i know the count. now all i need is the length of those..
by the way when you say 31-5/16", you measure the shaft's overall length without the lugs? or what?
Old May 10, 2010 | 06:13 AM
That measurement came from a few different parts suppliers.
Why don't you measure what you have? It sounds like you do not have the stock axle under there given the spline count. EVERYTHING I have read states that it should be 30 spline.
Old May 10, 2010 | 09:20 AM
yarinzim's Avatar
i guess i have no choice, it just bums me out to open the diff just to take a single measurement.
TexasRider
May 29, 2013 06:50 AM
harrymonkeyboy
Aug 4, 2011 04:54 PM
kxaz145
Apr 17, 2011 12:56 PM
tony991
Nov 27, 2009 09:06 AM
DLslotster
Tires and Wheels
Nov 23, 2007 04:53 PM
