Heater core hoses
Old Oct 1, 2009 | 06:21 PM
--SPEED--'s Avatar
--SPEED-- is on a distinguished road
VICTORY IS MINE !!! after 3 different taps I was able to get a nipple NOT the quick connect installed in the intake ! put teflon tape on the nipple just in case, but ran the vehicle for an hour and no leaks ! take that GM ! hope you have success junkie ! good luck !
Old Oct 1, 2009 | 10:47 PM
old skool luvr's Avatar
yeah, i kind of forgot to mention that junkie (happens when you're used to doing it yourself). make sure you use some pipe dope, or Teflon tape. the dope will never leak if you use it, but either one will do fine.
Old Oct 19, 2009 | 01:33 PM
92k5junkie's Avatar
92k5junkie is on a distinguished road
Here are the pictures of the connector and hose ( before ) if you have these you are in for a world of fun.
Old Jan 30, 2010 | 09:16 PM
92blazer92's Avatar
92blazer92 is on a distinguished road
So what do i do if my fitting didn't brake but the threads in the intake are so far beyond being taped. anyone have a remedy?
Old Jan 30, 2010 | 09:32 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
sadly time for a new intake. or you could try a helicoil. those are used more for spark plug threads on the block that get crossthreaded. but they may work.
Old Jan 31, 2010 | 12:00 AM
actually, that's the beauty of a NPT thread, you can still run the tap in the hole, it'll just go deeper, creating a little larger hole.
but you have to be really careful, it's easy to go too deep & create too large of a hole for the new fitting.
Old Mar 27, 2010 | 12:54 AM
Albone3000's Avatar
Albone3000 is on a distinguished road
Does anybody have a part number for the nipple that will work with the Vermont American 1/2-14Npt Tap Part Number: 20354?
I was able to unscrew mine without breaking anything (with the hose intact once I gave up on my quick connect tool) but im sure the quick connect will start leaking once I put it all back together.
edit
ok i think i found one from jegs is this the right one?
Chrome Heater Hose Fitting
1/2" NPT x 3/4" I.D. Hose x 2-7/8" Long
Part Number # 555-511111
http://www.jegs.com/i/JEGS/555/511111/10002/-1
Old Mar 29, 2010 | 12:48 PM
92k5junkie's Avatar
That looks like it will do the job nicely.
It looks better than the $3.99 part I got at the local Advance Auto:
http://shop.advanceautoparts.com/web...ci_sku=5707439
It's working great and no leaks, but I wanted chrome :-)
Dorman Heater Hose Connectors Nipple 3/4" Hose x 1/2" NPT x 2-3/4" Long Metal
If I only I could remember to paste in the details...
Old Mar 29, 2010 | 01:15 PM
Yeah, either of those will work!
Those pictures jogged my memory! We had to mess with this very thing on my dad's old '94 K2500 probably 10 years ago. We just ended up using a drill & tap. Dad put back in the same damn thing though...
95LS
Mar 31, 2014 10:51 PM
rza0122
Jan 3, 2011 04:39 AM
BlazinMike89
May 27, 2009 09:28 PM
ldkronos
Dec 13, 2007 03:54 PM
MudHawg
Dec 20, 2005 12:56 PM
