Hot starter problems m1009
Old Jul 18, 2010 | 12:26 PM
Jonas's Avatar
Jonas is on a distinguished road
Default Hot starter problems m1009
Ive got some major problems with the starter / starter solenoid getting to hot.
Usually have to sit in the truck and wait for 30mins for it to cool down after a drive. The starter is a 24V Delco starter and im trying to figure out how to remove some of the hot-contributing stuff..
On my current setup the starter always have 24V present on the battery connector... I wonder if this is contributing to the heat? Should i maybe only give the starter power when im starting the truck?
All help is massivley appreceated..
Old Jul 18, 2010 | 02:37 PM
Have you checked to make sure that the starter is disengaging properly?
Old Jul 18, 2010 | 03:33 PM
Jonas's Avatar
no sir.. how would I test that?
I absolutley dont think that its not disengaging.....
Its just sometimes when hot it wont do anything. Leaving the truck for 15-30 mins then trying again always works..
Old Jul 20, 2010 | 09:01 AM
Jonas's Avatar
today the car started fine 5-6 times while driving around to diffrent stores, then later after beeing still for 40mins when i was going home from the garage the truck started fine, i turned it off, then i tried to start it again, and it was dead.
Its getting frustrating... maybe its time for a new starter ?
Old Jul 20, 2010 | 10:50 AM
84BlazerS10's Avatar
I think if it's not disengaging you should be able to hear it trying to crank.
I think this is probably caused by a short in your ignition tumbler or ignition switch
Old Jul 20, 2010 | 11:25 AM
Jonas's Avatar
bypassing all the ignition just putting power to Start and Bat on the starter also fails, that should rule out the ignition system...
solenoid just wont close the bridge when its too hot.
Old Jul 20, 2010 | 11:43 AM
BigBlockBlazer's Avatar
BigBlockBlazer is on a distinguished road
Try a starter heat shield blanket.
http://www.summitracing.com/parts/THE-14150/
Mandrwj
Apr 10, 2011 07:32 PM
AllenEM
Jan 14, 2010 04:17 PM
Louie629
Jan 3, 2010 11:30 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
jug
Nov 30, 2007 02:44 AM
