I need fuel pressure testing help :-)
I have an 87 k-5 blazer. I went to g
o for wheeling the other day. I let her warm up, them out her in hear and she died :-( I can not get her going. If I prime her she Ttys to fire so I know it has spark. I'm thinking it is a fuel problem. Weller do I find the test valve to test the fuel pressure? And another advice is great!
all you can do is,buy a adapter for the throttle body off ebay etc. (search tbi fuel pressure adapter). Then go to autozone etc and "loan" a fuel pressure tester. Its free but you have to leave the retail deposit which is refundable when you bring it back.
it has to be between 10-13 psi.
*Moved to: Full Size K5 Tech*
I moved your thread to this section so you should be able to get some more help. Like Chris said start with the pressure test. Its the absolute best place to start in any "fuel issue" suspected diagnosis
Simple question, do you have fuel in the tank? You wouldn't be the first to solve the problem with $5 of fuel in a red can, me included
What do you mean "prime"? You mean when you turn the key the pump will whir for a few seconds?
When you say you know there is spark is that because as it cranks it 'almost' fires up?
e I'm doing it in the right place.
