ignition switch removal
Old Jan 14, 2010 | 08:36 PM
fireman11368's Avatar
fireman11368 is an unknown quantity at this point
Default ignition switch removal
hey im trying to replace the ignition switch on my 89 k5. i tried removing the two nuts holding the column but it doesnt lower. is there another way to get to it or do i need to remove the the steering column? thank you
Old Jan 14, 2010 | 08:43 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i think kyle had a thread on a how to. ill see if i can find it
here it is not sure if it will work for k5 but maybe it will help https://blazerforum.com/forum/showth...switch+removal
Old Jan 14, 2010 | 10:00 PM
thanks for the info those are instructions for the s10 blazer
Old Jan 14, 2010 | 10:03 PM
That they are...
So what exactly is the problem you are running into? You cannot remove the bolts that hold the ignition switch to the column? If so, you will likely have to drop the column down to get better access to the bolts that hold the ignition switch on.
Old Aug 17, 2011 | 11:42 AM
wy0mn's Avatar
wy0mn is on a distinguished road
Default Bump!
Working on a K5 Blazer.
I have the switch out and replaced, the actuator rods weren't connected to start with, so I can't just reverse the process. Cannot figure out how they attach given the angles bent into the rods (2ea).
The instruction with the replacement switch are gnarly.
Any help (photos preferred) would be uber appreciated.
Lex
Old Aug 17, 2011 | 12:22 PM
I'll see what I can find in my '90 R/V factory service manual when I get home.
Old Aug 17, 2011 | 02:02 PM
wy0mn's Avatar
Thanks man, but I spoke too soon.
Once I took the seat out, so I could get my fat head under there, everything fell into place.
Lex
Old Aug 17, 2011 | 02:58 PM
OK. Good deal! Glad you got it. I may still post up what I find when I get home.
Old Aug 26, 2011 | 11:18 AM
Suncrest Sniper's Avatar
Suncrest Sniper is on a distinguished road
You need to remove the bolts that go into the firewall on any GM steering column to lower it. Once those are out it will give you enough room to drop it down and access the dimmer switch and the ignition switch. I've done tons over the years and unless your doing a complete column rebuild there's no need to pull it from the vehicle.
SS
Brian5792
Oct 24, 2018 11:34 AM
austinlee
May 8, 2010 10:53 PM
vadatara2
Jun 24, 2009 01:39 PM
skoot61
Jul 6, 2008 07:18 AM
bambooboy21085
Nov 13, 2007 05:13 PM
