Injection convesrion
Old Jan 16, 2009 | 06:31 AM
pitouras's Avatar
pitouras is an unknown quantity at this point
Default Injection convesrion
Hallo,
Do you know which is the best carburator to injection conversion kit available?
thank you in advance
John
pitouras's Avatar
Default RE: Injection convesrion
i have the 1984 K5 blazer 350 engine
Old Jan 16, 2009 | 06:42 AM
What are your expectations? Do you offroad and want to be able to handle some higher angle stuff where fuel would run away from the jets in a carb? Looking for better performance?
By far the most economical route to go is grab an entire TBI setup off of a newer truck (wiring, ECU, intake, throttle body, fuel lines, maybe fuel pump, etc). Cost and complexity goes up from there.
Old Jan 16, 2009 | 06:48 AM
pitouras's Avatar
Basically i do offroad a bit...but the main reason is that injection system is more easy to drive arround...no cold weather issues and etc..
but from what i see its expensive (holey,ederblock)
Old Jan 16, 2009 | 07:04 AM
I would recommend trying to find a TBI truck in the junkyard to snag parts off of. You should be able to grab parts off of any truck from 89 to 95 or 96 (IIRC) so long as it is a TBI motor that has the same intake bolt pattern and orientation as yours (ie not a vortec headed motor). Get all of the parts that I listed above, but try to make sure that you have access to the truck all the way through the end of the conversion for miscellaneous parts that you may forget or find out later that you need.
Fuel is not too much of a concern, but I am not sure if you can use your stock mechanical pump. Aftermarket electric pumps with regulators would probably be the best way to go.
Old Jan 20, 2009 | 11:57 AM
DdayK5's Avatar
DdayK5 is an unknown quantity at this point
The junk yard is more then likly the best way, but you also have to consider the exhaust system as well. I don't know what you've done to the exhust but I didn't have a place for an O2 sensor until I purchased shorty headers. The conversions that I found were complete kits offering Multiport injection averaging $2000. The best thing I found for the cold was a manual controled chock.
Old Jan 20, 2009 | 12:23 PM
O2 sensors are simple to add. You can get a weld on O2 sensor bung for cheap and have an exhaust shop put it in for you if you do not already know someone with a welder. By far the cheapest route is the junkyard. Heck, you could probably find a rotted out pickup that someone will practically give you so long as you haul it out of their back yard. There are a few of those around me.
Old Jan 20, 2009 | 12:52 PM
DdayK5's Avatar
I wasjust encouraging that they may want the exhaust manifold as well as the intake. I didn't know of the weld on O2 idea, that may be easier then transfering an exhast manifold.
Old Apr 11, 2010 | 02:44 PM
killer_illusions's Avatar
killer_illusions is an unknown quantity at this point
anyone know how I would go the other way around??? I just put an older motor in my '89 fullsize and want to run my holley carb on it but runs real rough which it didn't do in my el camino I think it might be because the computer is controling the distibutor how do I get around that???
SlydinClyde
Oct 20, 2009 12:56 AM
00ZR2BLZRGUY
Jan 22, 2006 11:33 PM
HaulZ
Headers, Intake, & Exhaust
Sep 25, 2005 12:16 AM
timetoblaze
Sep 19, 2005 01:37 PM
02 Vortech
Engine & Internal
Apr 1, 2005 05:29 PM
