just got an 86 k5- carb linkage question
Old Jan 20, 2013 | 07:26 PM
Blazer_LT's Avatar
Blazer_LT is on a distinguished road
Default just got an 86 k5- carb linkage question
anyone know which linkages i can eliminate or if there is a way to hook them all back up the right way. had to toss the factory q-jet carb and put on an edelbrock performer 600. could not get all the linkages back on just the throttle would mount up. now i have 2 that are not hooked up could not find any threads anywhere. thanks in advance
Old Jan 20, 2013 | 10:18 PM
70-K5's Avatar
70-K5 is on a distinguished road
there are only two items to hook up, the throttle cable and the TV cable.
do not drive your rig with the TV cable not hooked up. If you do your transmission will soon blow up.
A quick search on Summitracing.com will result in an Edelbrock adapter for the carb.
Old Jan 22, 2013 | 09:33 PM
Blazer_LT's Avatar
ok thanks and i have 4, i think 2 are throttle one is cruise and one is the tv. cruise should be the one attached to the rubber cup right?
Old Jan 23, 2013 | 07:22 PM
abig84's Avatar
yeah cruise will be like some big rubber actuator. you have to buy the attachment for the kick down cable for these carbs. i bought one years ago and had the same problem, or you can just make your own with a bolt and some nuts but its kinda ghetto that way
Old Jan 24, 2013 | 10:20 AM
70-K5's Avatar
86 will have a TV cable, not a kickdown. The correct adapter is absolutely necessary to the function and life of your overdrive transmission. Spend the money and do it right or you'll be spending more money.
The cable pull needs to be specific.
Attached Thumbnails just got an 86 k5- carb linkage question-tvcableinstructions2.jpg
RnB1987
Mar 8, 2015 03:34 PM
Brandon Smith
Dec 22, 2013 12:33 PM
tony991
Lifting Tech
18
Jun 7, 2010 09:39 AM
R3MiX
Feb 17, 2010 11:12 PM
ivannj
Nov 28, 2005 09:43 PM
