k5 blazer 79 overheating
Old Dec 12, 2021 | 06:41 PM
BLAZERK5CHE's Avatar
BLAZERK5CHE is on a distinguished road
Default k5 blazer 79 overheating
Good night young people, I have a little problem with my k5 blazer 79, when driving 20-30 minutes in a climate of 28-30 degrees Celsius, it stops and does not turn on ... the temperature clock rises more than normal (it is not very good so I don't trust the clock), when the weather is 20-24 degrees celsius the blazer works great but it shows that it needs more cooling, the radiator is the original bronze, it is at 70% of its capacity because it has Damaged cells, water does not filter, this with green American water (I am from Latin America) they recommend me to make the damaged cells of bronze or change for a 2-3 cell aluminum radiator. What else would I have to look for for faults related to overheating, the water pump is optimal, I use American 5-30 oil, 350 5.7L stock engine with a 2bbl rochester carburettor, I don't use A/C.
Old Dec 12, 2021 | 07:20 PM
Does it happen more at high speed or low speed? If it's at low speed, the problem may be your fan clutch. When the engine is hot, have somebody turn it off while you watch the fan. It should stop turning in 1-2 seconds. If it keeps spinning, it's bad. Also, do you have a fan shroud? If it's missing, that could be part of the problem.
Old Dec 12, 2021 | 08:02 PM
It happens on normal drive in traffic, at high speed got no problem... Stop like 1-3 seconds, the fan shroud is fine
Old Dec 13, 2021 | 04:55 PM
Default Update
Cells were welded, I already did repair and maintenance, only now when we tested it, I accelerated and started sucking from the radiator cap (I tried it with my hand, it tells me that I have to see the pressure and that it is in delayed time ... any ideas...?
chevy dude
May 12, 2012 08:55 AM
wornknobby3
Aug 2, 2011 07:29 PM
usmc0311
Mar 13, 2011 09:12 PM
JohnCG2002
Sep 2, 2009 10:26 PM
Blazin 4x4
Sep 21, 2005 05:02 PM
