k5 pissing me off
ok here it is 87 350 auto she runs good untill wormed up then she losses power on take off after a few she pickes up and goes with out aney help she sat for a year so i replaced ecm,tps,o2,knock,coolent temp sencer,all new dis. in and out,plugs,wires,new ful pump,intake gasket,esc,iac,rebuld on tbi,oil pump,rod berings, when i droped the tank cleand out put back she seemed to run wors after that. I am soooooo lost. and there is no codes. im abought ready to replace the prom and map sense thats all thats left. im going to rebuld the moter so i dont mined having all new on the out as well. but I do need this runabilty fixed.
what about the temperature sensor for the computer. the one located on the front of the intake. had a truck at work that was running like crap and thats all it was. was telling the computer it was running at like 19degrees always
Have you replaced/checked your vacuum lines yet?
I just fixed my EGR system and I started having your problem semi-frequently, but not 100% consistently. I thought it was maybe a bad egr solenoid allowing the egr valve to open, but yesterday I found a cracked plastic vacuum line between intake&egr when I did my intake manifold gasket. (not the first, but usually I notice when I break one)
If my problem persists I'm going to replace the map sensor. I think you can try running with the map harness disconnected to see if it's your problem, but don't quote my on that =).
Did you try running with the map sensor disconnected? If there's no change it's not that.
Measure your coil resistance values (primary & secondary). Edit: Er, n/m I missed where you wrote 'all new dis in and out'
let us know if you figure it out.
