LS Swap 72 Blazer
Old Jun 24, 2018 | 12:22 PM
tfaryniarz's Avatar
tfaryniarz is on a distinguished road
Default LS Swap 72 Blazer
I just purchased a 1972 Blazer with a fuel injected 396 and turbo 350 transmission. It runs perfect but I am going to swap out the drivetrain with a 2016 L83 engine and 6 speed auto trans I just purchased. Has anyone here performed an LS swap into an early Blazer? I am looking for as much info as possible so I can start collecting everything needed so my rig is off the road for as little time as possible. I will be using the stock wiring harness, drive by wire pedal and all accessories as I currently have a/c and plan to keep it. I thought I read somewhere that the front crossmember will need to be changed out. Can anyone help me with my research? Greatly appreciated. Thank you
Old Jun 26, 2018 | 12:51 PM
LesMyer's Avatar
Looks like these people have it all figured out. If I was going to do it, I would contact them and see if they have a guide, or at least ask them what you will need. https://www.dirtydingo.com/shop/prod...oducts_id=1408
P.S. Isn't a 2016 a Gen5 LT engine, not a LS? Not sure if the mounts are the same but probably are. Oil pan - better ask. Sounds like a REALLY expensive swap! But to each his own.
https://www.lsxmag.com/tech-stories/...our-next-swap/
Pops5193
Performance & Brainstorming
Aug 4, 2019 10:16 PM
ezrollin
Dec 22, 2018 11:38 AM
Bejaran
Jun 17, 2016 06:55 AM
Liftedsas
Jun 28, 2015 03:54 PM
jcrum1989
Engine & Internal
Dec 7, 2014 07:22 AM
