manual choke good idea?on my 78
hey i got a 78 k5 dosnt start withouht starter fluid so i figured out the choke dosnt close i held it closed and fired right up so i figured id put one of the 8.99 manual chokes in is that a good idea ?
oh yeh what years are interchangable for a 78k5
Last edited by swartlkk; Feb 18, 2010 at 08:06 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT function to add additional information to your post if another member has yet to reply.
i agree with trying to fix what you have or going aftermarket if you got the coinage.
Look on the passenger side of the carb. There should either be a large electric choke can or an arm that extends down into a little tin cover located on the intake manifold.
If you have the arm that extends down towards the intake manifold, this would be the automatic thermal choke setup. The cover just pulls straight up. The arm should go into a loop on the end of a coil. It could be that the arm is disconnected at the coil or the coil could be broken. Or, all of this could be missing entirely.
