Multifuction Stem
Old May 30, 2009 | 12:12 PM
MikePots's Avatar
MikePots is on a distinguished road
Default Multifuction Stem
Im changing my mulitfuction stem. Do I need to remove my steering wheel to replace?
thanks
Old May 30, 2009 | 12:45 PM
oisinirish's Avatar
Service manual for mine says steering wheel needs to be removed. I've never done it so there may be a trick to keep you from having to pull it though.
Old Jun 1, 2009 | 07:31 AM
Mike, please put your vehicle information in your signature so that those of us trying to help do not have to look back through your posts to find your vehicle information.
If the 94 steering column is anything like the s-series, then it would be possible to remove the upper and lower steering column covers and swap out the multifunction switch without removing the steering wheel. As stated above, the book procedure does state to remove the steering wheel, same as the s-series repair procedure. In the later s-series columns, there is one screw that is quite difficult to get out with the steering wheel in place, but it is possible.
I would pull off the steering column covers and have a look at it.
Old Jun 3, 2009 | 01:02 PM
MikePots's Avatar
all fixed. had to remove the wheel. thanks for the advice.
boscoedoodle
16
Aug 16, 2012 04:53 PM
kwilli
Mar 14, 2012 07:05 PM
drb
Apr 10, 2010 09:44 PM
PHATSPEED7x
Oct 29, 2009 03:50 PM
speakerwire
Sep 26, 2008 10:46 AM
