need a help with my 89 blazer
Old Jul 7, 2010 | 10:11 PM
nicco89blazer's Avatar
nicco89blazer is on a distinguished road
Default need a help with my 89 blazer
im pulling code 23 and cant find what it is. also my blazer is stock and pretty guttless any tips on some quik power boost's. it needs more power bad and not to sure were to start and i want to put 411 gears in where is the best place to buy them i will install my self
Old Jul 8, 2010 | 12:37 AM
84BlazerS10's Avatar
Ask a auto parts store they should be able to tell you what the code is.
Old Jul 8, 2010 | 04:16 PM
88 rusty but trusty's Avatar
88 rusty but trusty is on a distinguished road
Code 23 is intake air sensor
Old Jul 8, 2010 | 07:49 PM
mr.vls's Avatar
What engine do you have? My 89 has a 4.3 and has decent power. The only mods are KN air filter, Injector Spacer, Adj. fuel pressure regulator, aftermarket CAT. Also mine is 2WD Auto.
Old Jul 8, 2010 | 10:51 PM
i have the 5.7. i read the codes wrong it was a 32 erg fault. i changed the egr and checked all the vacume lines. i just dont know why it is so gutless. it has very poor acceleration. could this be the timing
Old Jul 8, 2010 | 11:10 PM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
My first off the wall guess would be plugged catalytic converter.
Old Jul 8, 2010 | 11:19 PM
i think that is it but it was my uncles truck and he said it has always been week. i have a 88 silverado same 5.7 and it has power for days. i dont get it.
Old Jul 9, 2010 | 12:25 AM
rriddle3's Avatar
Okay, first off, you started 4 different threads concerning the same issue. Please read the Forum rules and you will see that double posting is a violation. I have combined your threads, so please keep everything in one thread and folks can follow what is happening.
You say you have a 5.7L engine in an '89 Blazer, but is it in a K5 (full size) Blazer or has it been swapped into a 1st Gen S-10 Blazer? Complete info about the vehicle will help.
Asking why a vehicle has no power is like asking why you can't throw a football well. We would need a lot more info concerning the symptoms (when it occurs, what you have tried to correct the problem, history of any other symptoms, etc.). How many miles are on the engine? How long since a complete tune-up? Have you done a compression test on the motor?
Old Jul 9, 2010 | 03:52 AM
the truck runs fine other than being gutless. and the tps is new and the head gasket not blown. the truck trys to over heat when towing and has a stutter for a second when u mash the throttle down from a dead stop. it is slow getting up to speed. it will not do more than 45 40 mph with trailer up even a slight incline. and struggles to do 60 up hill with no load.
Old Jul 9, 2010 | 09:20 AM
rriddle3's Avatar
Can you please answer these questions from my previous post?
Originally Posted by rriddle3
...You say you have a 5.7L engine in an '89 Blazer, but is it in a K5 (full size) Blazer or has it been swapped into a 1st Gen S-10 Blazer? Complete info about the vehicle will help.
