new coil now engine misfiring and no power
Old May 8, 2010 | 01:09 AM
Meanagersmom's Avatar
Meanagersmom is on a distinguished road
Angry new coil now engine misfiring and no power
Son has 90 K5 blazer. He was driving it week ago, engine sputtered and just died, He said it turned over starter working but would not start. we know the coil was in need of replacement. Dad had it towed to shop and they replaced coil and starter? dont know why starter but they did. Dad then had stereo shop disconnect remote starter. Immediatley after now the truck is barely running, rough idle, like missfire, no power, dies out and I have checked everything, coil , coil wires with volt meter, it is getting fuel, there was a leak in line to fuel filter, fixed. Recently replaced egr vac syl , re checked not the problem, control module changed , not the problem. The heater core went on it about 3 weeks ago and have not yet replaced bypassing it. rotor and cap are new, new spark plugs as well as fuel filter. No vac leaks as far as I can tell. Anyone have any ideas. I am at a loss here??? I know jeeps not chevys Help
Old May 8, 2010 | 09:08 AM
abig84's Avatar
Check the timing also recheck the firing order maybe they got swiched around.
Old May 8, 2010 | 03:44 PM
checked firing order, all okay there, need to check timing. thanks for suggestions. Any would be appreciated. Really getting tired of wasting time and money.
Old May 8, 2010 | 03:48 PM
I have a question for anyone out there, I have read on these forums a lot about a coolant temp sensor causing similar problems? There is still a somewhat strong fuel smell from exhaust. Like perhaps running too rich? Where is this thing at and how would I go about changing this or at least unplugging it to check to see if running. When the hearer core went, the temp shot up suddenly and wondering if that could have done something to this thing? Anyone??? Any advice???
Old May 8, 2010 | 04:57 PM
abig84's Avatar
Could be. Happened to a 91 at my job. It just kinda ran crappy. But its like right on top of the engine at the front. Its only like a $5 part. I don't know how you can really test it. We plugged it into the computer and when the truck was at operating temp it was telling the computer it was still cold so it was dumping more fuel
Old May 9, 2010 | 03:10 PM
I'll give that a try. Thanks again.
Old Jun 13, 2010 | 11:33 PM
Shaggy's Avatar
Shaggy is on a distinguished road
Do you have spark? I would suggest checking the wires on the pickup coil, especially since you recently did the cap and rotor. Those two wires are VERY thin and if original they are probably very brittle.
blainenbecky
Mar 9, 2013 10:38 PM
bse8881
Mar 15, 2011 12:24 PM
Lancealot
Feb 22, 2011 07:34 AM
ExplicitYourSelf
14
Jun 7, 2010 06:25 PM
ff_holt1
May 14, 2010 01:35 AM
