New Tires, Highway Concern
Old Oct 3, 2009 | 10:43 PM
mafiaboy01's Avatar
mafiaboy01 is on a distinguished road
Question New Tires, Highway Concern
Hi, I am the proud owner of an 87 K5 Blazer(6.2) 4x4. I currently got new tires(not on the car yet) and have a few concerns. I know it is gonna mess up the speedometer a little bit but that is not a major concern.
The problem is that I am planing to drive it to New Jersey from Toronto Ontario in late October and have a concern. I have read that many people(including myself) have problem maintaining a constant speed on the highway. I don't experience as much troubles as others but it may down shift now and then.
I am worried that with the bigger tires this problem will intesify and I will not be able to keep a good 100-120 km/h speed in OD. I was wondering if this is a problem and what are the things that can be done to the truck to make it run nicer on the highway.
As of now I have no problems getting up to speed on the highway and need to give about 1/4 to 1/2 gas to keep the car running and the right speed.
Thanks
Phil
Old Oct 4, 2009 | 07:59 AM
If you were having trouble maintaining speed with smaller tires, it will likely get worse with larger tires. You have two options, make your motor stronger, or change the gears.
Old Oct 4, 2009 | 08:15 PM
mafiaboy01's Avatar
Thanks for the quick response. Well making the motor stronger is kinda out of the quesiton since the only way would be to add a turbo(to much money). Now when you say change the gears do you mean in the transition or in the differential?
Old Oct 4, 2009 | 08:46 PM
You can hop up a diesel without adding a turbo. It is just harder and almost as expensive as a turbo kit.
As for gears, I was speaking of the differentials.
Old Oct 4, 2009 | 09:53 PM
BlaziNator's Avatar
BlaziNator is on a distinguished road
cb96
Nov 6, 2012 10:27 AM
tjmicsak
Mar 21, 2012 05:48 PM
krob1218
Aug 18, 2011 11:25 AM
Hanr3
Dec 19, 2006 08:16 AM
