NO BRAKES!!!
NO BRAKES!!!
Ok well got the truck onthe road today..got the new (used rear) but when I went to ake it for a drive I notcied my brakes are horrible..the pedal goes straight to the floor..I didnt disconnect any brake lines in the process of changin the rear so i dont need to bleed the system...but when i did drive the truck to my shop in school the axles walked out on me and the drum separated from the brake assembely and i hit the brake when i saw that..could my wheel cylinder have jus blown up??but there was no brake fluid leaking from the cylinders or anything so im lost...
RE: NO BRAKES!!!
Do any rear end work lately? Sounds like a C clip went awol. The drum may fall off if there is no wheel on, and no lugs installed. Where the shoes installed correctly?
I can't fathom what else could casue this.
RE: NO BRAKES!!!
the axles walked out on the odl rear when i blew it not the new (used rear)
RE: NO BRAKES!!!
ok, the old rear end, I see. Is there vaccum? (brake boost)
RE: NO BRAKES!!!
ill have tocheck..i didnt disconnect any lines in the process of swapping the rears..but when a wheel cylinde blows will there be brake fluid leakingeverywhere?? becuase i think thats what the problem might be the i dont got any fluid leaking anywhere so i dont actualy know if the cylinders went or not..
RE: NO BRAKES!!!
yes there would be brake fluid if they go.
RE: NO BRAKES!!!
yea i think the brakes need adjusting then..cause the left rear self adjuster is jammed up so i am just going to replace that and see if it helps any..
RE: NO BRAKES!!!
All nice n rusty? always common. Might as well get a whole new hardware kit. Goods luck this weekend.
RE: NO BRAKES!!!
great now my parking brake dosent work...
RE: NO BRAKES!!!
just off the top of anyone's head do i have to take all the springs off the rear breaks to get out the self adjusters or could i take them off without taking all of it apart..
