No check engine light at start up
Old Nov 6, 2010 | 05:40 PM
starfish's Avatar
starfish is on a distinguished road
Unhappy No check engine light at start up
My starter just crapped out on me so I went and got a new one.I hooked every thing up.She turns over but she won't start.I noticed that the engine light dont even come on when I turn the key now.I tried to pull codes out and i cant get the engine light to come on at all.I dont even hear my fuel pump kick in when I turn the key on.1987 Blazer 5.7 with TBI.Could my computer have burned out from the bad starter?Or would a bad modual do this?
Old Nov 6, 2010 | 05:48 PM
rriddle3's Avatar
If you don't hear the starter turn over, then something didn't get connected correctly.
Old Nov 6, 2010 | 05:58 PM
starfish's Avatar
the starter turns over fine.when I crank it over,it seems like there is no power to the computer.The check engine light dont come on when I crank it over and I dont here the fuel pump kick in.
Old Nov 6, 2010 | 06:02 PM
rriddle3's Avatar
Checked all the fuses and relays?
Old Nov 6, 2010 | 06:05 PM
starfish's Avatar
fuses and relays are all good.Ive been outside for 6 hrs checking wires fuses and so on.
Old Nov 7, 2010 | 06:49 AM
starfish's Avatar
Default 1987 Blazer 5.7 TBI engine cranks over but wont start
I just put on a new starter and it turns over but it wont start.When I turn the key half way the CEL light wont come on and I dont hear the fuel pump kick in.I rechecked the wires and I noticed that the new starter has another small bolt were the wires hook up.In other words,my starter had 2 spots to hook up the wires ,and the new starter has 3.
Last edited by rriddle3; Nov 7, 2010 at 08:54 AM. Reason: I HAVE COMBINED YOUR TWO THREADS. PLEASE KEEP DISCUSSIONS CONCERNING THE SAME ISSUE WITHIN A SINGLE THREAD.
Old Nov 7, 2010 | 09:12 AM
If the starter is turning the motor over, then it is wired properly.
Sounds like maybe your ignition switch has failed.
Old Nov 7, 2010 | 03:25 PM
starfish's Avatar
even if I turn the key back to acc,the CEL light should come on for a moment but It doesn't so I'm pretty sure the ign. switch is ok.my next guess would be the coil or the ign. modual.I wish I new for sure, cause I dont have the money to throw around.
Old Nov 7, 2010 | 04:12 PM
I wouldn't call that a confirmation that your ignition switch is acting normally...
Old Nov 9, 2010 | 10:23 PM
8five-k5's Avatar
8five-k5 is on a distinguished road
i had this problem before...messed around wit the distributor motor cranked right up...
