Np 241 problems
Old Aug 6, 2009 | 11:05 AM
ta3ff's Avatar
ta3ff is an unknown quantity at this point
Default Np 241 problems
I have a 93 with the NP 241 transfer case, in neutral I can go into 4LO. I put her back in the neutral position in the transfer case, from there on it a mad grind fest.
I know there a linkage to the transfer case, can that be adjusted? Could the thermal switch be on the fritz? I think I read somewhere online there is an updated thermal switch.
On the bright side I rebuilt me 700R4 all by myself, and it worked. WOOHOO!!!
Thanks
Old Aug 6, 2009 | 12:04 PM
The transmission needs to be in neutral and the truck stopped or only slightly rolling whenever you change ranges (HI to LO or LO to HI).
Old Aug 6, 2009 | 12:32 PM
ta3ff's Avatar
I've tried that...
Old Aug 6, 2009 | 12:40 PM
If the transmission is in neutral, then there should be nothing to grind as nothing in the transmission would be moving. Are you sure that your transmission shift linkage is adjusted properly so that neutral is true neutral?
Old Aug 6, 2009 | 01:32 PM
ta3ff's Avatar
Ah, now that's one thing that I haven't looked into closely. I was so happy just to get her road worthy.
Cool, I'll check her out when I get home.
thanks
xgiovannix12
Dec 19, 2011 05:08 PM
Aanenson
Apr 14, 2011 09:12 PM
jayfire
Oct 25, 2009 07:48 AM
upblazer95
Apr 4, 2009 08:27 PM
