question & advice about hidden safety switch
Old Mar 21, 2010 | 12:56 PM
yarinzim's Avatar
yarinzim is on a distinguished road
Default question & advice about hidden safety switch
i want to make an hidden safety switch on my fuel pump, as a precaution.
when i disconnected the ground from the pump the fuel gauge went all the way up. and when i reconnected the ground it came back to the right position.
my question is - will i make any damage to the fuel gauge or the pump itself by connecting and disconnecting it every time i want to drive the truck?
plus, i'd love to get some ideas about things i can disconnect as a precaution. maybe the ignition module or something, any idea will be appreciated.
Yarin.
Old Mar 21, 2010 | 03:31 PM
abig84's Avatar
I've always done the ignition. That way the truck cranks and the theif will think truck is a turd and move on.
Old Mar 21, 2010 | 11:19 PM
yarinzim's Avatar
and by ignition you mean ignition module? no problem with disconnecting it?
Old Mar 26, 2010 | 02:38 AM
yarinzim's Avatar
still want's to know if you meant the ignition module..?
Old Mar 26, 2010 | 03:38 AM
ohsofly's Avatar
I would think the ignition module in the engine bay would be east to do. Just clip the ground for the module, and get 6 feet of black wire and solder it into where you clipped the ground in the modules harness. Now pick a spot behind your bumper for your 2 prong finger switch, and hook both those ground wires up to it.
Then when you parked in shady areas you would just casually flick that switch on your way by the front of your truck and open the ground circuit on your ignition module and no start...
Old Mar 26, 2010 | 06:20 AM
If you have the HEI distributor, you can just put a relay on the +12V coil lead. The truck won't start if you don't have spark! Problem is, if you forget, you can flood the engine pretty quickly.
Old Mar 27, 2010 | 03:21 AM
yarinzim's Avatar
i believe it's a standard distributor..
Old Mar 27, 2010 | 06:43 AM
Yeah... Ok. I'm not going to go back through your posts and determine what year you have. It is quite possible that your distributor is an HEI distributor. They came standard on many models and were used to upgrade the old points style distributors all the time (that's what I did on my '74).
If the coil is located on top of the distributor cap, it's an HEI distributor.
Old Mar 27, 2010 | 02:38 PM
yarinzim's Avatar
sorry i forgot to mention - it's 90 k5.
i need to check the location of the coil, i can't remember..
Old Mar 27, 2010 | 04:13 PM
abig84's Avatar
Sorry I didn't clarify. I cut the main red lead going into the HEI. And put a toggle. Someone else told me to ground it out when I first did it and I forgot to flip off my kill and fried my ignition module inside the distributor
