Rear Axel Seal Leak
Old May 15, 2017 | 06:46 PM
sdarnell2618's Avatar
sdarnell2618 is on a distinguished road
Default Rear Axel Seal Leak
Just purchased a 1974 K5 Blazer in California. Drove it back to Oregon about 6 hours. K5 is in great shape, it was a good daily driver for the guy I bought it from. When I got home of course a few leaks started popping up. The rear driver side axel started leaking fluid. I took rear diff cover off, dropped the pin, removed C clips and pulled the axel out. There was a rebuild seal and bearings kit in place instead of the normal bearings and separate seal. The seal was in bad shape as well as the fluid. I cleaned everything up and put the new rebuild kit I purchased in place and put it all back together and then changed the other side as well since I already had rear end tore open. I put everything back together changed the fluid, new gasket and silicone and thought I was good. I drove around for a few hours and noticed the next day I had a pretty big leak out of the same side as the original leak was coming from. I am stumped now on what to do.
Old May 15, 2017 | 07:00 PM
What did the axle shaft look like? Any grooves on the exterior of the shaft?
How well did the new bearing/seal fit into the axle tube?
Old May 16, 2017 | 11:46 AM
yeah there was some small grooves and it wasn't extremely smooth and clean. I am new to the mechanic stuff so didn't cause any alarm in my mind until now. Drove it to work today and noticed as I get into parking lot and slowed down a loud growling type noise and the feeling of something hanging up and not turning smooth. So not sure whats going on now.
toms2000blazer
Sep 29, 2013 07:55 PM
ComputerNerdBD
Aug 9, 2011 08:04 AM
litterbug
Mar 7, 2011 09:14 PM
MotoLappa
Aug 19, 2009 11:53 PM
mwacker
Jun 29, 2009 09:14 PM
