Rear power window
Old Aug 25, 2008 | 11:15 PM
Blazerr's Avatar
Blazerr is an unknown quantity at this point
Default Rear power window
Have a "86" full size w/power everything, don't know how far the rear window is suppose to retract, all the way? Mine has retacted only to the point of about 1/2" remaining above the weatherstripping in the middle. I have owned this "Blazer" since 1988, divorced 2 yrs ago & for $400.00 I kept it with blown head gaskets. Decided to junk the stock 350 & the computer BS and dropped in a "69" vette 350/375hp + other upgrades, roller rockers, etc. 450+ hp, reworked the 700r4 (no electronics, all manual). I am going piece by piece and restoring a good ride (lots of fun! Lots of power! Cal smog - No Problem!) Can anyone tell me about the rear window?
Old Mar 13, 2009 | 06:55 PM
kustomdlx454's Avatar
kustomdlx454 is on a distinguished road
I belive it rolls down all the way to protect the glass when you put the tailgate down. I am having problems with mine too. It wont do anything, but thankfully it quit working when it was closed.
Old Mar 14, 2009 | 08:14 AM
holeshot63's Avatar
holeshot63 is an unknown quantity at this point
when the window is down all the way there should be about 1/8" of it showing. i have just done some work to mine. what is it doing when it stops moving. sounds grinding poping anything like that?
Old Mar 15, 2009 | 02:00 PM
It has stopped in the up postion. When trying to operate it from the switch mounted on the dash, it does absolutely nothing. I am blaming the switch on that one. When you operate it from the key switch on the back of the tailgate, it makes a click sound when you turn the key in either direction, but the window does not go up or down.
I dont want to tear apart the whole thing if I have to because I am just home on a small vacation and it is my dad's blazer. I would like not to leave it apart, and have to go back to school in a week or two.
Old Mar 16, 2009 | 12:08 PM
Originally Posted by Blazerr
Have a "86" full size w/power everything, don't know how far the rear window is suppose to retract, all the way? Mine has retacted only to the point of about 1/2" remaining above the weatherstripping in the middle. *snip* Can anyone tell me about the rear window?
Anywhere from a tiny bit extended up to 1" is what I have seen from quite a number of K5s. I believe there is a low level switch or some other safety feature that tells the rear window motor when to stop that can be adjusted.
As far as your problem kustomdlx454, you really need to get in there and determine if the motor is the problem or if the window is bound up. If you decide to tackle this job, please create a new thread as your problem and the originally posted problem are different.
e602
91
Mar 8, 2015 04:53 PM
bigslik20
Aug 9, 2011 11:32 AM
rossg
May 27, 2009 07:48 AM
JTAF
Oct 14, 2007 10:09 PM
bigghoss
Apr 15, 2007 01:39 AM
