Rear Window Handle/Crank
Old Dec 13, 2012 | 09:08 PM
KOETTINGSINC's Avatar
KOETTINGSINC is on a distinguished road
Default Rear Window Handle/Crank
So I just bought a 76 blazer and the rear window crank is missing. I ordered all of the parts from LMC. I can not for the life of me figure out how the pawl and spring go in. I have sit here for hours trying to do this. I searched for pictures and write ups but nothing out there to explain if you have nothing to compare it to or if you have never seen the thing assembled any help would be greatttttttttttttttttttttttttttt!
Old Dec 14, 2012 | 01:09 PM
anyone
Old Dec 16, 2012 | 07:34 PM
still searching everywhere and cant find anything
Old Dec 16, 2012 | 07:53 PM
This is the best I could come up with from my illustrations manual:
The pawl (52) & spring (51) feed in from the bottom prior to putting the barrel (46) on the back (inside) side of the crank handle assembly (49). You have to push the lock cylinder (48) into the bore so that the pawl/spring can slide in. Then slide the barrel (46) over and install the snap-ring (53) to secure the lock cylinder & barrel in place.
Attached Thumbnails Rear Window Handle/Crank-k5_tailgate_crank.jpg
Last edited by swartlkk; Jul 9, 2013 at 05:54 AM. Reason: Added item numbers from illustration
Old Apr 25, 2013 | 05:20 PM
ralphb1969's Avatar
ralphb1969 is on a distinguished road
I too have the same issue and want to add that this by far is the best description and illustration I've seen. I am however still unclear. can you cross reference the part that you mentioned to the part numbers in the diagram As I am unclear what part you're referring to when looking at the illustration? that would help a lot.
Old May 15, 2013 | 03:32 AM
T...K21's Avatar
T...K21 is on a distinguished road
Those were notorious... Almost a "right of passage" to at least R&R one of those while owning an older Blazer/ Jimmy.
Old May 16, 2013 | 06:59 PM
abig84's Avatar
cant you just buy these things complete? i remember buying one like 8 years ago from a parts store in town, you just bolt it on and your done.
i remember my first k5 didnt have one, had to use a pickle fork to roll that window up and down
Old Jul 8, 2013 | 08:06 PM
805K5's Avatar
805K5 is on a distinguished road
I am trying to fix mine. I have the basic jist of things. One thing I can't figure out. How do I secure the lock cylinder in the crank handle? I have seen the schematics calling for a "pin" but I don't see where that goes in. Also, if it isn't a pin, how does the snap ring attach to secure the actual lock cylinder?
e602
91
Mar 8, 2015 04:53 PM
Jimmy Williams
Feb 16, 2013 11:36 AM
jmatson
Jan 8, 2013 12:48 PM
mjsk5blazer
Nov 2, 2010 08:43 PM
thebeast1980
Jun 11, 2008 01:05 PM
