rear window stuck up but I need to get it down what do i do??
Old Nov 3, 2007 | 07:16 PM
88beater's Avatar
88beater is an unknown quantity at this point
Default rear window stuck up but I need to get it down what do i do??
Hi everyone,
My rear window motor/complete setup is shot but I need to manually get the rear window down so I can pull the top off. (to high to lift top over window) Can anyone tell me how to lower the rear window?
Thanks in advance
Rob
Old Nov 3, 2007 | 07:43 PM
Chevy Lover's Avatar
Default RE: rear window stuck up but I need to get it down what do i do??
You should be able to remove the trim panel and access the motor.
Did the motor just die?
Try tapping the motor with a small hammer while someone operates the switch.
Old Nov 3, 2007 | 07:49 PM
88beater's Avatar
thanks I just figured it out I had to search deep in the dirt at the bottom of the door there was the cable that is supposed to run from the window to the motor.(it isnt hooked up) so for the mean time I just plugged it to the window and to my drill and worked fine. but thanks for the help. As i was writing the forum in a panic I realized what i needed to do. Eitherway it helped. Thanks for giving it a shot I am sure I will have a ton more questions.
Rob
teryx750
Sep 25, 2021 08:14 PM
e602
91
Mar 8, 2015 04:53 PM
littleguns
Nov 26, 2013 10:06 AM
dunlap3
Jul 16, 2012 06:14 PM
GolfClapperX
Jun 5, 2009 03:48 PM
