Removing the Rear Window on Tailgate
Old Jun 5, 2010 | 01:49 PM
84 Bucket of Bolts's Avatar
84 Bucket of Bolts is on a distinguished road
Default Removing the Rear Window on Tailgate
Is there any directions on how to remove the rear window on a power tailgate?
Old Jun 5, 2010 | 04:58 PM
Lower window. Drop tailgate. Remove bolts at the bottom of the regulator. Remove window.
Old Jun 7, 2010 | 03:56 PM
Of course i tried that but, the last little bit of the window seem to be stuck in a track or something. Is there anything still holding it in?
Old Jun 7, 2010 | 04:02 PM
Once you remove the 4 bolts holding the window to the regulator, the only thing that would stop you from removing the window would be the weather stripping at the top of the tailgate. That can be removed, but you have to be careful not to damage it. The easiest I have found to remove the weather stripping is to drop the window into the tailgate as far as you can, then push the weatherstripping down in to disengage it. Then pull it out.
RobRad
Mar 24, 2014 06:08 PM
87muddyblazer
Nov 10, 2009 05:59 AM
USMaverick101
Nov 20, 2006 01:20 PM
mwjungaz
Aug 24, 2006 09:10 PM
sleonh
Mar 29, 2005 03:32 PM
