Shifting
Old Jun 26, 2007 | 08:56 AM
74green's Avatar
74green is an unknown quantity at this point
Default Shifting
I have a 1978 K5 4wd blazer with manual trans. I dropped a new motor in it, put on a new clutch on the transmission and now cannot get the Trans to shift into any of the gears. The blazer wasn’t running when I bought it so I am unsure if maybe something is mechanically wrong with the transmission…..It just wants to grind[:@] going into every gear….Ideas?
Old Jun 26, 2007 | 09:55 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: Shifting
Yeah, it sounds like the trans may need rebuilding or replacing. Check the stick linkage, and make sure the changer isn't stripped.
Old Jun 29, 2007 | 06:26 PM
Chevy Lover's Avatar
How does the clutch feel?
If you put it in gear, step on the clutch, is it actually disengaged? If it's ok and you engage the clutch, does it move ok?
I'm wondering if it's possible that the clutch disc was installed backwards.
96jimmy4x4in
Oct 7, 2007 09:23 PM
4WD Rookie
Mar 6, 2006 10:41 PM
TMAN
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Feb 26, 2006 03:16 PM
Chevychick
Feb 13, 2006 04:32 PM
Swblazer
Aug 15, 2005 01:41 AM
