smog and alternator problems.
Old Sep 5, 2010 | 11:23 AM
83k5blazer's Avatar
83k5blazer is on a distinguished road
Default smog and alternator problems.
I'm stumped. everything was working fine. one day when i was on my way back from fishing. i noticed by battery was not charging. i take the alt. to get checked and it was ok. but the guy at the auto parts store told me it did not have enough amps for the truck. i bought the right one 78 amps and put it on now a squeaking noise coming from the smog pump it ran great for a few days (still making the squeaking noise) then the same thing battery went down to 8v. so next i did the same with the battery store said it was ok, but same thing alternator wont charge. any ideas?
Ive checked all wires and starter. made sure the battery ground was good. another thing when i disconnect the 2 wire that plug in to the alternator the smog pump stops squealing wired any ideas?
thanks for the help.
Old Sep 5, 2010 | 01:47 PM
Is it still squealing? Maybe there is a problem with the smog pump that is causing the belt to slip on the crank?...
Old Sep 5, 2010 | 03:56 PM
83k5blazer's Avatar
yeah its still squealing. it only stops if i unplug the 2 wires from the alt. the belts not slipping. it all most seams like the alt. is draining the power not adding power to the battery
Old Sep 6, 2010 | 07:46 PM
83k5blazer's Avatar
thanks swartlkk it was the smog pump i took it apart today and cleaned everything and presto no squealing and the alt. is charging 13v. but after i drove it a while here comes the squeals but at least i know its the pump :-) im thinking of removing it sense we dont have emissions where i live. 406 stroker one step closer !!!
Thanks for the help
Old Sep 6, 2010 | 07:48 PM
Glad to help!
Bolbol
Aug 31, 2014 01:10 PM
Jason Method
Mar 19, 2013 08:02 PM
JHH
May 22, 2012 09:54 AM
gearhead23
Aug 15, 2011 09:37 AM
nezoic
Nov 7, 2009 08:00 PM
