speedometer cabling
Old Apr 17, 2008 | 10:17 AM
Loofah's Avatar
Loofah is an unknown quantity at this point
Default speedometer cabling
My speedometer doesn't work, I am going through the system in an attempt to find out why. Does anyone know where the speedometer cable gets it's signal from in the engine compartment (or wherever it may be). This is a 79 full size with an automatic transmission and no cruise control.
Old Apr 21, 2008 | 01:24 AM
BigBlack73's Avatar
BigBlack73 is an unknown quantity at this point
Default RE: speedometer cabling
It's connects to the transfer case, not sure what side, assuming you have an NP203, it's on the right side facing the rear. the end of the cable has a kind of square part and a threaded cap that goes around it, which threads onto the spot on the transfer case. i have a 73 blazer with a similar problem, but my problem is that i put an NP205 in it and the spot where the speedo cable connects is on the other side, making my speedo cable to short :/ lol. i just gauge it by what gear i'm in and what RPM's i'm runnin at. hope i could help!
AlaskanK5
Jan 10, 2010 10:32 PM
smokey94
Nov 7, 2006 07:44 PM
bellert
Aug 31, 2006 03:19 PM
mgrnwd
Jul 14, 2006 01:24 PM
swartzy
Tires and Wheels
15
Mar 22, 2006 11:59 AM
