speedometer changed to machanical....???
Old Sep 30, 2010 | 06:35 PM
KaneK5's Avatar
KaneK5 is on a distinguished road
Question
I have a 85 k5 with a new process 241 transfer case, I am trying to put a machanical speedometer in the truck and transfer case tail shaft has electronic hook up on it... Can this be changed to machanical and if so what is the process.
Any help with this would be greatly appreciated, Thanks
The old gauge i pulled out was machanical, so im not sure if tranfer case or its the gauge thats not orignal for this year?
Last edited by swartlkk; Sep 30, 2010 at 07:53 PM. Reason: Combining Consecutive Posts - Please edit your post to add additional information/questions if another member has not yet replied.
Old Sep 30, 2010 | 08:12 PM
If you are set on using a mechanical speedo, you will need to find the rear bearing housing from a '89 blazer or suburban. '89 was the first year for the NP241 in the K5 & Suburban and the ONLY year available with a mechanical speedo.
Or you could do the SYE (slip yoke eliminator) conversion to the rear output which will come with the mechanical speedo parts.
Old Sep 30, 2010 | 09:04 PM
KaneK5's Avatar
will either one of these options require any modifactions to drive shaft? longer, shorter? Where can i aquire the parts for the conversions (sye). Sounds eaiser then the hunting game of year specifect transfer case? Not sure was just trying to go easy and cheap on this gauge swap
Is the bearing housing part of the transfer case or is this just the transmission tail shaft housing? not sure of this
Last edited by swartlkk; Oct 1, 2010 at 11:34 AM. Reason: Combining Consecutive Posts - Please edit your post to add additional information/questions if another member has not yet replied.
Old Oct 1, 2010 | 11:40 AM
If you do the SYE conversion, you will have to get a new rear driveshaft that can extend.
If you just change out the rear housing (and possibly the rear output shaft), you should be able to reuse your driveshaft.
Another option, albeit expensive, is to get an electronic to mechanical conversion box.
Old Oct 1, 2010 | 07:06 PM
KaneK5's Avatar
do you know of any links to web sites to look at these options?... going start searching craiglist to for a case. Really appreciate your time and info with this...
EuroGoldLS
Dec 24, 2007 05:14 PM
Chevyguy032
Apr 14, 2007 12:34 PM
mogley99
Mar 31, 2007 09:16 AM
LT1KICKER
Oct 23, 2006 04:00 PM
carpentercb
Mar 9, 2006 08:57 PM
