steerin problem
Old Nov 19, 2010 | 09:49 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default steerin problem
hey i have my truck put back together new heads and running pretty good ..i put a new powersteering pump while i was at it because i have an awful screeching problem when i turn hard like a u turn or backing out but wnyway the new powersteering pump didnt fix the problem its a little better but its still embarrasing with that god awful screeching anyone know where to start since it aint the pump??its a 78 k5
Old Nov 20, 2010 | 04:13 AM
Did you get it bled out fully?
Old Nov 20, 2010 | 09:23 AM
abig84's Avatar
how much lift and do you have a lifted steering arm or anything to correct the steering angle?
Old Nov 20, 2010 | 10:24 PM
i think its a 4 in lift i dunno i personally havent lifted it yet but its pretty high compared to a stock blazer.. no i didnt bleed nothin
Old Nov 21, 2010 | 09:09 AM
abig84's Avatar
if the steering angles arent correct it might be a reason. cause instead of the gear box just pushing and pulling like its designed to do its also pushing downward and pulling upward taking alot of strength away from the push/pull set up like its designed to do
Old Nov 21, 2010 | 09:28 AM
robertr728's Avatar
robertr728 is on a distinguished road
Is the belt loose and squealing?
Old Nov 21, 2010 | 05:29 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
my old scotsdale used to do that the p/s gear box was binding up replaced it and was good to go
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
bigwes
Feb 28, 2009 09:56 AM
Daytripper540
Mar 29, 2007 03:54 PM
