still have tranny problem
Old Jan 15, 2010 | 08:54 AM
johnpimentel72's Avatar
johnpimentel72 is an unknown quantity at this point
Default still have tranny problem
hi,
i've had this problem since i bought it and did a lot of things already. finally today, with my friends, i had the time to look for the electrical problem coz i occasionally use this. saw the "P1875 explained" post and most of my searching said to look for the circuit from the pcm to the tccm which is a gray wire with black stripe on a 4pin black connector. however, i couldn't find the wire, it's either black or gray only without stripes and they all go down to the underside not the pcm. correct me if im wrong but is the tccm located at the back of the driver side air vent near the door? i hope somebody could post pictures where these are located so it could be a lot easier.
thank you very much.
2000 silverado auto transmission 4.8l with 4 button 4x4 switch
Old Jan 15, 2010 | 09:02 AM
Considering that your truck is neither a s-series blazer or a fullsize blazer and that the trouble code sheet applies to the s-series vehicles, I would not expect the wiring to be identical.
Old Jan 15, 2010 | 09:12 AM
thank you for the fast reply sir. any ideas on how i could have this done. it was your sticky that i read and was full of important info.
davtak
Jun 28, 2011 08:47 PM
riggankl
Jun 28, 2011 05:01 AM
Eff10
22
Dec 8, 2009 07:21 PM
butters
Nov 17, 2009 07:21 PM
J_man01
Engine & Internal
Jan 13, 2007 10:03 PM
