still stalls and dies when goin slow
hey i cant figure this out when im in rverse or goin slow from a stoplight the whoile truck shuddders and stalls mostly when i dont give it a ton of gas to get it not to stall it dosnt shift well unless i let off the gas and itll switch intpo the right gear so i think i got a vaccum thing in my transmission but could this make it shudder and stall when going slow?also when i stop and turn it off it shudders and makes a souind like it releasing a bunch of exhaust ..it pops kinda like a backfire befor it dies also..ive adjusted the carb done the timeing a bunch replaced some vaccum lines i just dont get it ..please help 78 k5
He means the EGR valve (The EGR valve helps your car more efficiently and completely burn fuel by recirculating a portion of your exhaust and running it through the combustion process again. This results in a cooler, more complete burn of the fuel which decreases you car's noxious emissions by prohibiting the formation of some harmful gases.), it should be located on the intake manifold. Here's a picture of it, EGR Valve for 78 K5
im guessing my EGR valve is bolted straight to my maifold under my carb but theres a smaller similar lookin thing with a vaccum hose goin to it under my distributor but im guessin its the bigger one under the carb oh yeh its a 78 k5 350 whats the tourque on the egr valve?
to block off just unbolt and bolt on plate with new gasket, could not find the bolt torque specs on it but i just tighten it down. as for the vacuum line just block it off
egr+block+off+plate - JEGS High Performance
