TB 350 only idles in open loop
Old Jun 17, 2013 | 03:52 PM
LS1K5's Avatar
LS1K5 is on a distinguished road
Default TB 350 only idles in open loop
My friend has a 1987 throttle body 350 that would intermittently die at idle and now won't idle at all unless the timing connector is disconnected, then it runs perfectly at low to mid rpm/load. No codes except 42 from the connector unplugged and all the sensor data looks good. I can get it to idle with the connector plugged in by spraying carb cleaner in the TB but the IAS is wide open. PS while the engine is running in closed loop there are all kinds of codes PROM TPS ect, it seems like a PCM problem has anybody seen this before?
chasisjr2012
Aug 27, 2012 01:59 PM
chris015
Feb 14, 2012 10:20 AM
Survivor
23
Dec 30, 2009 07:53 PM
caddy500
Oct 2, 2009 11:23 PM
caddy500
Aug 9, 2009 01:54 PM
