Timing Question
Old Apr 25, 2010 | 01:23 AM
mjchris's Avatar
mjchris is on a distinguished road
Default Timing Question
i have a 1973 307 sbc, 2 barell carb, hei ignition,bone stock only mod. is long tube headers this is in a 1979 k5 ,my question is what degree is base timing set at ? and should my vacuum advance be hooked to direct manifold vacuum or not and the same with my egr valve what type of vacuum should it be ran to ? please help
Old Apr 25, 2010 | 03:43 PM
The EGR valve should be connected to the EGR solenoid and then to the intake manifold.
I always prefer to have my distributor vacuum advance plumbed to a direct manifold vacuum source.
Base timing... I would adjust base timing for the maximum engine vacuum at hot idle in gear. Do this with the vacuum advance disconnected. It should be somewhere around 8-10 degrees advanced.
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
1990blackgt
Dec 27, 2007 03:32 PM
