UGHHH happend again..
Old Dec 8, 2006 | 01:36 AM
Chevyguy032's Avatar
Chevyguy032 is an unknown quantity at this point
Default UGHHH happend again..
ughh well did that today....I tightened the loose rocker arm....well my shop teacher said it looks like it is pulling the stud out so i jus tightend it up..but jus a hour ago i am driving than i hear the ticking again...ughh wut should i do?? he mentioned taking the heads off and taping the stud..?????very confused
Old Dec 8, 2006 | 02:19 AM
Chevy Lover's Avatar
Default RE: UGHHH happend again..
Are you sure it's the stud or is it a collapsed lifter or worn cam lobe?
Which cylinder is it?
Old Dec 8, 2006 | 02:36 AM
20Blazer00's Avatar
If it is the rocker stud there are after market studs that will thread into the head and if you do this then you will have other options down the road for upgrades to the valve train.
Old Dec 8, 2006 | 06:49 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
stock gm heads used press in studs. the rocker studs are just press fit into the head. its possible that the fit has loosened up and the movement of the valve train is pulling the stud out of the head.
to avoid this problem the old stud is pulled from the hole, the hole is tapped out and a screw in stud is used. this is common in performance applications.
http://store.summitracing.com/partde...5&autoview=sku
if its just a problem with that one rocker stud you can probably put a screw in stud in that one that is being a problem without removing the head.
the other option is to pin the stud. you leave the original stud in but drill a hole into the head at the bottom of the stud, then insert a pin through the head and stud to lock the stud in place and keep it from pulling out. this could also be done with the heads still on the truck but you'd probably have to remove the intake to get the angle you need with a drill...
either option should be able to be done carefully without disassembling the engine. but you should make sure that it is in fact the problem. it could also simply be a worn rocker nut that isnt holding, in which case a new nut or poly locks (rocker nuts with set screws in them) would keep the rocker nut from loosening on you.
(you'll have to double check that any of the links i posted are the right sizes for your application, i just posted them so you could see examples)
Old Dec 8, 2006 | 04:14 PM
cylinder 8..and I most likely know its the rocker stud...because of how much thread was showing and how locse the rockwer arm was and let me tell you that thing was RADICULOSLEY..but he said the best method is the tap...so hpefuly ill be doing that next week in shop...
Old Dec 8, 2006 | 04:27 PM
ORIGINAL: Chevyguy032
cylinder 8..and I most likely know its the rocker stud...because of how much thread was showing and how locse the rocker arm was and let me tell you that thing was RADICULOSLEY lose..but he said the best method is the tap...so hpefuly ill be doing that next week in shop...
Old Dec 8, 2006 | 07:50 PM
if its pulling out it should be pretty easy to spot since that stud would be taller than all the others.
it should be a pretty do-able job for you, just be careful that the metal shavings dont get away from you and you should be fine.
Old Dec 9, 2006 | 12:27 AM
how hard is it actualy to take the stud out??and the put then new in one..will i need any special tools??..and it is the intake on cylinder 8 that has the bad rocker stud..
Old Dec 9, 2006 | 12:59 AM
irocknrol2's Avatar
irocknrol2 is an unknown quantity at this point
years ago in the race engines, we always would peen the studs because the force on the springs was so great, it would pop that stud out. Not a big deal for a machine shop to do.
Old Dec 9, 2006 | 07:06 PM
to get the old one out, they do make a tool to remove it. your shop teacher should be able to help you here, he may have the tool to do it or know how to improvise with what you have available.
to put the new one in you simply need a tap to thread the old hole for the new stud. then it bolts right in with a socket or wrench.
gatelocked
Feb 28, 2011 04:52 PM
ImScrewed92
May 16, 2010 09:19 PM
KRUSHER
Jan 2, 2010 07:25 PM
Jhop16
Dec 9, 2005 07:56 PM
JVS
Jun 12, 2005 11:00 PM
